跳转到主内容
Here are the repair guides for Xiaomi Redmi Note 4X
Why cannot the other party hear me?
I called up several phones and all parties cannot hear me but I can hear them. How do I resolve this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Try using the earphones with the microphone attachment or using the phone in loudspeaker mode (or hands free mode) to check if you can be heard when on a call.
If you can be heard then there may be a problem with the phone’s internal microphone or perhaps the voice inlet hole, located on the bottom edge of the phone may be blocked with lint etc.
To check the latter possibility, use a strong light and a magnifying glass to inspect the voice inlet hole.
If it appears to be blocked (or even if you can’t tell), try using a vacuum cleaner to clear the blockage. Do not use a pin or probe to try and clear the obstruction as you may damage the microphone which is directly behind the hole.
If you still can’t be heard when using the methods above, try starting the phone in safe mode to determine if it is a hardware problem (faulty microphone) or if it is perhaps a downloaded app that is the cause of the problem
If it still doesn’t work in safe mode then you have a hardware problem.
这个答案有帮助吗?
得分 3
1条评论:
Thank you so much... thanks to your advice i recognized a bad part on Xiaomi note4x (purchased new botom Mic part was bad from factory)
完成的
添加一条评论
添加你的答案
Carmel Pizarro Chammag 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 35
总计 3,699
