跳转到主内容
13" laptop part of Dell's E6000 series, released 2011. The device features a removable battery, optical drive, and is compatible with a variety of E-Port docking stations.
WIFI card DW1510 Capacitor removed during shipping. Is it necessary?
Hello,
I Order a Dell dw1510 wifi card to replace my non working dell card. When it come in , it have a small smd capacitor that it was peeled of during shipping. Does anyone know what can this capacitor do? Is it important part for the card? Anyone have schematic about this card? Can the card work without issues without this smd capacitor?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I would return the board if you can, otherwise see if you can solder it back on.
这个答案有帮助吗?
得分 3
5条评论:
I try to solder it in, but I don't have the micro tools required to do it and this idea failed. Also I don't know if there is polarity in this part. Sadly , the return shipping is more than the total cost of this card and I try to install it in the system, to see what is going on with it. For a strange reason the card is working n Linux , but I don't know if it is working stable and correctly. It is detected and can be connect to a network. Speedtest work as expected, but i don't know if this capacitor removes the mimo functionality from the card and makes it single band... Do you know any method to test if it stable? Can this be a power saver component?
完成的
Without reviewing the schematic and board view you're just guessing on what its function is.
If it works then it maybe nothing more than a noise filter.
完成的
Yes, I need the schematic. I hope that someone can help me to find it...
完成的
Broadcom does not offer them as far as I know.
完成的
I speak with seller and he sent me a replacement card. Thanks for the informations!
完成的
添加一条评论
添加你的答案
ssavva05 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 184
