跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
Spilled a tea on my MacBook keyboard
Hi,
I’ve spilled a tea (no sugar, no milk) on my Mac keyboard. It was 1/3 of 0,4l glass, so not that much. Also, the tea is not that acidic, is it? I immeditally plugged everything off and switched the device off. Then I left it upside down for 24hrs to dry it out and to let the water eventually come out. After that, I took the Mac to the closest Apple store. They did run a diagnosis test and no issue was found, everything just works fine.. However, I was advice to make a repair of a top case with keybord and trackpad - the cost is £300. I have a deadline for my Masters dissertation in two weeks and need to use the laptop.
Could anyone please tell me if I can use it when the diagnostic test has not found any issue? Is there any chance that I’m just a lucky guy and the laptop passed with no damage?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
exact same here, what happened and what did you do? what do you advice me?
完成的
添加一条评论
1个答案
已选择的解决方案
your better having the logic board cleaned and the keyboard changed as a precaution. corrosion will happen overtime and just because its still working atm doesnt mean it won’t stop working at some point due to the liquid damage
这个答案有帮助吗?
得分 3
1条评论:
This is the correct answer.
完成的
添加一条评论
添加你的答案
Patrik Huber 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 11
总计 2,395
