LCD temp connector issue
Hi all!
Could you tell me please, is this possible to fix?
Thanks!
You’ll need to find a replacement socket and then you’ll need to carefully remove the broken one and install the new one.
I would recommend you find someone with the needed sills and access to the needed part. This is not an easy fix.
这个答案有帮助吗?
It seems like i cant just buy a required part, i should find another motherboard from which i should remove and replace it?
Do you have an independent computer repair shop near you? I would let them fix it. The connector is a standard part. Even still you might be able to find a junker to steal the part from. While replacing the entire logic board will also achieve the same end result it would be the more expensive route.
No, i think full logic board replacement is not a solution for me) You said thats the connector is a standart part, thats interesting, i thought its unique.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 68
