picture off and on sound ok
LG55LF6000
Picture flashes off and on rapidly . Sound stays on smoothly
Try several sources, all direct wired. I’ll assume you’re using HDMI. If issue persists, use a flashlight to see if it’s a backlight problem (I doubt it). If issue goes away, especially on more than one source, something between source and display isn’t compatible with the source HDMI stream. Saw this on an older AV rcvr w/HDMI switching. Turned out the rcvr version of HDMI processing was too down rev to handle the source bit rate. Display would go all black, or white intermittently. Bypasssing the rcvr worked fine.
这个答案有帮助吗?
Thanks Sarge,
It was on the antenna port w/co/ax from a digital adapter ...and had a surveillance controller on HDMI . Both work fine on 2nd tv.
How to use flashlight for backlight test has my curiosity now pls. do tell.
Jerry
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 31
