跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
keyboard won't backlit after battery replacement
Hi:
After replacing the damaged battery, the backlit on my keyboard won’t work anymore. I did the ambient sensor test with the camera and unchecked the options for adjustment on the preference menu. Im currently using the latest version of Mojave. The keyboard used to work and I used the video provided by this channel, which was very helpful. Any suggestions what could be going on? I’ll appreciate any tips.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
Have you tried SMC reset?
(SMC=System Managment Control)
Here is a link how to reset it: https://support.apple.com/en-us/HT201295.
完成的
Hmmmm,that's tricky question.
完成的
Where you get the battery?
完成的
Unfortunately, I had to get it from e bay, instead of here in fix it because of shipping issues. The postal office won't handle lithium batteries.
完成的
完成的
显示更多的2条评论
添加一条评论
3个答案
已选择的解决方案
Yes I did. Unfortunately, it didn’t work. I also installed the OS from scratch with no success. I feel very disappointed since I just finished removing the cover to double check every connection. And as expected, everything looks good. The webcam works, the keyboard works. So I guess is if the battery is none-genuine apple product, might that be the reason?
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
It seems I wasn't the one who had this problem. Meh, I gave up trying to make it work properly and just ordered a new device. Thankfully, I found a seller close to my zip code in Phoenix https://worldpostalcode.com/united-state...
这个答案有帮助吗?
得分 1
添加一条评论
thank you. I had a closer look and the backlit connector was still unplugged under the logic board. I missed the connector during assembly. I carefully managed to pull it out and there it was. now its working.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jose L Ramirez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 963
