跳转到主内容
加入维修社区 - 创建账户
Gaming laptop released in 2014 with an Nvidia 860M graphics card and a 15.6" display. Updated in 2015 with 960M graphics.
Screen turned pinkish with green lines
I bought this laptop in 2015 so the warranty expired in 2017.
ISSUE: Today when I turned on the laptop, I saw pinkish text with green lines come up right from the start ("Lenovo" text in the beginning) and it leaves temporary traces of previous window/pane when I move to another one.  I have all the drivers/components up to date and there isn't any issues found when I ran few check ups.
What can be the possible solution to it? OR do I need to buy a new LCD/connector for the screen?
HELP!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi Faisal
well, test with an external monitor /display to confirm.
you can try reaseating the LVDS cable and see if it helps.
完成的
Hello Augustine, thanks for the response.
I haven’t tested with external monitor but will do.
How can I access and check the LVDS cable to see if it’s seated fine?
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @splash104 ,
Here’s a link to the service manual for the laptop.
Scroll to p.65 onward to view the necessary pre-requisite steps and then the procedure to remove the LCD unit particular to your model variant. This should give you access to the cable.
If you determine that the problem is with the LCD panel itself, on p.93 you will find the part numbers for the various panels.
If you search online using the part number only, in the search box of your browser, (appropriate to your particular model variant), you will get results for suppliers of the part.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Faisal Sidd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 945
