跳转到主内容
Repair and troubleshooting guides for the Acer Aspire V3-571G-9686. This 15.6 inch laptop was released in October of 2012.
20 个问题 查看全部
Green line in right side of the display.
Hello. I own an Acer Aspire V5-571G laptop, with IPS LED Display, 1080p resolution. Suddenly, a vertical line has appeared in the right side. It changes the color, on white is green, but on black it is not visible. Do i need to replace the display or maybe is just the connector?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Răzvan Alexandru
well, test with an external monitor /display to confirm the lines is on your laptop display.
you can try reaseating the LVDS cable and see if it helps.
what you are seeing line … most probably the lcd display bonding on your laptop display is not well bonded.
you can try stripping till you see the lcd module, and try applying light pressure to it.
sharing a video, fyi.
https://www.youtube.com/watch?v=UNf81Z-i...
imo the video is a short temp fix.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Răzvan Alexandru 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 259
