跳转到主内容
Guides and support for various television (TV) brands and styles.
9051 个问题 查看全部
How do I test the voltage of my power supply?
My Sharp LC-50LBU591U won’t turn on and is showing no standby light so I suspect something is wrong with the power supply. How do I check if it’s getting power though? I have a picture. The AC input is in the bottom left of the power board.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Ok so on the bottom right you have a bridge rectifier. The center pins should have access line voltage and the outer pins should have 1.4x DC line voltage. If there's nothing on the rectifier then find the burnt fuse. It looks like the board has multiple switch mode power supplies that are “low component count" alias cheap as possible. Difficult to diagnose, especially without a schematic or service manual. A factory tech would either fix it in 15 minutes or change boards when 15 minutes ran out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Nguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 535
