跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
678 个问题 查看全部
iPhone 8 Plus Powe button not working after battery replacement!
Hi,
I replaced the battery on my iPhone 8 plus and after the replacement all the other buttons work except the power button. The home button works etc and so does everything else on the phone.
The iPhone does have warranty (which I did not know as I bough it used) but will apple not help me because there isn't a genuine apple battery or would they not care??
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Are you comfortable enough to open it up again?
If so check all the connections to the logic board, make sure nothing is loose or torn on the right side.
You could take it to Apple for repair but they’d likely notice the battery and charge you for any repairs.
这个答案有帮助吗?
得分 0
3条评论:
Yes, just did that and all the connectors look fine and so do the flex cables which are visible not sure about the power button flex but that should be ok since I only touched the battery
完成的
Do you still have the old battery? You could put it back in and head to apple
完成的
You can turn on accessibility for the time being. This article explains how
https://www.macworld.co.uk/how-to/iphone...
完成的
添加一条评论
I suspect you have damaged the power button flex when trying to remove the elastic tape at the top. hang in a new flex to see if the problem is restored.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hamza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,686
