跳转到主内容
加入维修社区 - 创建账户
XFX 680 芯片组的精简版,成本更低。
How do I bend back my computer?
My Toshiba computer fell and now I have it in a certain way. How to I try to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@bearin A picture of the damage would be nice
完成的
添加一条评论
1个答案
已选择的解决方案
You will have to disassemble your laptop and see what’s broken and whether it’s fixable.
With the exact model number you should be able to find a disassembly guide, either here on iFixit or elsewhere. You may need to consult one or two to get the full picture.
Plastic parts of the case frequently break, in fact this is the usual cause of a broken hinge (i.e. not actually the hinge itself at all). Two-part quick setting epoxy glue is the best method of fixing, provided it has enough surface area to grip onto and provided you can accurately reposition any parts that have actually broken off, especially bushes that screws screw into.
Alternatively you could always look out for another laptop of the same model offered on eBay as “spares or repair” but with an intact case, and swap over as much as the guts as you need to.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Urso Major 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 1,017
