跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Black Screen after LCD replacement
I followed the guides. I replaced the LCD screen, moved all parts and installed to new screen. Cables are not broken. The screen after turning on, is black. Not dim in bright light. Just black. I tried with iTunes, comes with error 4005. I put back the old original screen. The problem remains. Now is Xmas and all services are closed. Appreciate for ideas.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I took to the service today, I had managed to brake the ID Sensor cable. Now screen works, and with installed graphical home dot on the screen. I am talking to Apple, if they allow this home key unit to be replaced. It can be done, but cost maybe half of the phone cost. Evaluation continues. Will see. Thank you anyways for your good advise.
完成的
添加一条评论
2个答案
已选择的解决方案
You should try seeing if any connections are loose and or broken. There could be a small piece in the connector broken when you replaced it.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
It sounds like you’ve damaged the LCD chip when repairing the screen, the fact that you can’t see the display even in bright light such as a flashlight eradicates the backlight filter out of the problem. I’d say you’ve accidentally damaged the LCD chip on the logic board when replacing the screen.
Also, check all connections from the flex cable to the LCD are tight.
Unfortunately, you’d have to replace the logic board to replace the LCD Chip.
Hope I could solve your problem.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Mikael Keinonen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,105
