跳转到主内容
加入维修社区 - 创建账户
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
Why my car doesn't start except I press the accelerator?
When I try starting my car, it won't start until I step the accelerator down.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Sounds like you need to clean the Idle air control valve. It would be a good idea to clean the throttle body while your at it. This video should help . Hope this helps
这个答案有帮助吗?
得分 1
添加一条评论
Merry Christmas!
Several car components may lead to this problem, you may diagnose each of them.
1. Check Air Filter
2. Assess Fuel Filter
3. Inspect Fuel Pump
4. Examine Compression
5. Test Throttle Body
Hope this info is helpful.
这个答案有帮助吗?
得分 1
1条评论:
This answer was very helpful to me. My mechanic failed, but with the answer and the aid of the YouTube video I did it myself. I did clean the idle air control valve with carburetor cleaner. Though it took a little bit of time to start.
完成的
添加一条评论
添加你的答案
Franklin A.Vaye 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 170
