跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
SSD Connecter broken Help
Hello All,
I recently dropped my MacBook Pro and while opening it I saw that my SSD Connecter component is missing. I have no idea where it went. I added some pictures in the blue. Any idea where I can fix it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Do you have the SSD drive? Was it floating inside?
完成的
No I do have the SSD Drive but the component fell out while opening.
完成的
You'll need to find it! It's VERY IMPORTANT!
完成的
Unfortunately I cannot find it. Anywhere else I can buy it?
完成的
添加一条评论
1个答案
Sadly thats not good ;-{
At this point you’ll need to find someone with a junker logic board to salvage the connector as well as the SSD drive.
Frankly, I think you’re better off just getting a new logic board as well as a new SSD drive.
Or, concider just buying a new system (used or new) to replace yours and sell yours for parts.
这个答案有帮助吗?
得分 0
2条评论:
Do you know any website that sell junk logic boards? Issue is buying a new MacBook is getting very expensive every year.
完成的
Get a good used system it's a lot cheaper!
Check eBay for junkers but I'll warn you may need to get a few to get a good part and you'll still need to get a SSD drive to replace yours. You would still need to find someone with the needed gear to fix your logic board (thats still assuming you didn't damage it to the point it couldn't be saved.
MacBook Pro 15‘’Retina显示器2015年中期主板交换
完成的
添加一条评论
添加你的答案
Deep Sheth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 71
