跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2396 个问题 查看全部
iPhone 4 charger not 100% going in but charges just fine
I recently purchased an iPhone 4 on ios 5 for $10 on eBay the phone fully works (i got it for cheap because it had no battery) but when i plugged it in i noticed the charger was starting to come out. Can someone please help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You would have to clean the charger port but that could cause the charging port not to work because the connector is usually worn out in this case.
Worst case scenario you would have to replace the charging port.
Here are guide and parts from iFixit if needed:
iPhone 4 Dock Connector Replacement
[关联产品丢失或禁用: IF182-009]
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
ryoseo1020 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 44
