跳转到主内容
个人电脑常见和不常见电线维修
How to rewire a OTG Cable easily without soldering?
My OTG cable was broken a bit so I can’t connect to anything? So how can rewire a OTG Cable easily without soldering?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
I wanted an otg cable and saw a DIY on YouTube. I had not soldered for 20yrs or so. Picked up a cheap solder pencil iron and flux. I made 3 cables that same day lol
Learn how to solder. It's super easy. Anyone can do it. Once you get the technique down you can pretty much make any specialty cord, adapter, speaker, microphone, guitar pickups….really the possibilities are only limited to your ability/experience. Learn how to solder buddy. It's a very practical skill to have.
Advice…use flux always. Lots of videos say you don't need it. You need it. It makes a world of difference.
Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Hi @mateam8424 ,
You don’t state where the cable is broken.
If the cable is broken close to the USB connector, either end, which most likely is a molded plug then you’ll have to replace the plug which requires re soldering the wires.
If the cable is broken away from the plug and you have enough length to work with, then you could cold twist joint the wires and insulate them but this is not electrically sound and is bound to cause problems.
Save yourself from the potential problems of not soldering the wiring. OTG cables are very cheap to purchase new. Just search on Ebay etc.
这个答案有帮助吗?
得分 3
添加一条评论
You can try twisting open ends together by hand and then isolating them, however it is very unreliable and possibly dangerous.
这个答案有帮助吗?
得分 1
1条评论:
So, how? Can we do that without soldering them back?
完成的
添加一条评论
添加你的答案
Ricky Cheung 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 2,467
