跳转到主内容
Entry level Photosmart printer introduced in 2009. Uses HP Tri-Color ink cartridges with a disposable printhead.
14 个问题 查看全部
问题已关闭
Color ink not printing?
The black ink prints fine but nothing for the colored one. I replaced brand new cartridge but no color comes out. When I checked the supply level, it says Genuine HP color ink and show full bars. Is the printer dying? New OS X won’t print in color? Anyone knows what the issue might be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论:
Hi @iwizmod ,
Do you get colour when copying directly from the printer's control panel?
Can you verify what is the OS of the computer connected to the printer?
Have you checked the printer settings in the computer to ensure that it is set to colour printing and not black and white?
完成的
Hi @jayeff,
I did a lot of research regarding this problem before posting here...including "Photo Copy" directly from the printer. I'm running OSX Mojave on my desktop and High Sierra on laptop. I even resetted all printer settings and re-added the printer. I double checked to make sure it prints in color and not gray scale.
So my last resort: ordered another ink cartridge and test it out again. This would be my third cartridge...if this doesn't work, then this printer is only use for b&w printing...bummer.
完成的
Hi @iwizmod ,
Did you do a printer alignment when you replaced the cartridges?
Just double checking ;-)
完成的
Hi @jayeff,
No, I did not perform a printer alignment...I usually don't when replacing a cartridge. I recently placed the black one and did not do an alignment...but I can try it now...
The page comes out in black and white too. I also scanned the printed page for the alignment. Then did a photo copy directly from the printer but still no colored ink...so sad!
My new ink arrives tomorrow...
完成的
Hi @jayeff,
I got my new ink cartridge and tried it. Looks like it’s printing in color again but not very vivid. Perhaps the previous cartridge was faulty.
I’m happy this printer still works!
Thanks for your help!!! Merry X’Mas!!!
完成的
添加一条评论
1个答案
umm, what i think could of happened is either: you haven’t put the ink cartridge in properly or something is wrong with the cartridge
这个答案有帮助吗?
得分 0
1条评论:
something was wrong with the cartridge...even though it was brand new out from the box.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,296
