跳转到主内容
加入维修社区 - 创建账户
Maxima 在 2009 款车型上进行了重新设计,并在 2008 年纽约国际车展上首次亮相。
Radio only works from steering wheel controller
My radio(non bose) only works from the steering wheel controller….It does not light up nor do any of the buttons work on the actual unit, I can change channels and volume from the steering wheel though…..any ideas.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This is actually as strange as it sounds a problem with the clock spring in the steering column. The problem will be in the ground on the clock spring . You will find 2 grounding wires on the backside of the clock spring . One is for the radio and the other is for the other controls on the steering wheel . This one is now actually grounding the stereo and as a result the unit itself is not grounded. The only grounding the stereo has no is a cheater from the cruise control . Replacing the clock spring doesn’t help you will need to replace the harness that comes into the clock spring up the steering column. Or you can solder the ground if your handy with a soldering iron . Hope this helps
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Vance Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,373
