跳转到主内容
加入维修社区 - 创建账户
带有清脆敲击感的机械游戏键盘——全键可编程,配备 5 个宏按键。2010 年首次发布。
The keyboard lights up but the keys do not type or do anything.
The keys light up and when I click them the lighting effect changes but the keys do not type.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 32
12条评论
when you have issues whit your keyboard whit a lot of keyboards when your keyboard doesnt respond to anything and the caps lock is lighting up its locked try to find the manual if you dont find how to unlock it its basecly just fn + windows key or there is a lock on if still not work fn + esc 3 sec and factory restart and it works so tadaaa
由完成的 分享
My gk61 is doing something where on alt, fn, and the number row light up and no keys will register I need help. Also when I click control the key R lights up but it doesn’t do anything
由完成的 分享
My Havit multi-function Backlit keyboard HV-KB558CM keyboard led works but my keys dont pls help
由完成的 分享
GUYS please help me i have a logtech keyboard it is the logtech g910 whenever i plug it in only half the keyboard lights up but it lights up then turns off and lights up then turns of not the keyboard the color turns off my keyboard is not blutooth btw and the keys only work when the light is on i tried everything i tried the water imerssion trick and it dident help. You guys are my only hope the fate of my gaming carreer rests on you guys.
由完成的 分享
okok just listen dont use water for any keyboard you numbskull
由完成的 分享
显示更多的7条评论
添加一条评论
12个答案
最有帮助的答案
You need to:
unplug the keyboard from your pc/laptop
then press and hold esc and M5
then plug it back in (while holding the keys)
then release the keys
and ta-da
这个答案有帮助吗?
得分 46
45条评论:
dude i literally just made an account to tell you, thank yoou this worked for me wtf lmao.
由完成的 分享
I've spent 8 hours trying to solve this. checked on youtube and googled with no results.
This solved it immediately! : D
Too bad I next beat the chit from keyboard in all the anger ...
由完成的 分享
my keyboard doesnt have m5
help
由完成的 分享
THANK YOU SO MUCH! I made an account just to say this
由完成的 分享
Mine doesn't have M5 key too, please help
由完成的 分享
显示更多的40条评论
添加一条评论
  1. Unplug the Keyboard.
  2. Press and Hold the Escape button (Esc), and Caps Lock (Caps)
  3. Plug in the keyboard to a USB port
  4. Release all keys
This solution is for windows users.
这个答案有帮助吗?
得分 28
24条评论:
Thank you, this worked
由完成的 分享
This actually helped me so much after like 10 hours of trying to fix it thank you
由完成的 分享
F**king genius. Thank you SOOO MUCH!
由完成的 分享
Didn’t help.
由完成的 分享
This did the opposite of help, my keyboard does not work anymore because of this... It is stuck in a loop of pressing the button ”TAB”... Do not try this
由完成的 分享
显示更多的19条评论
添加一条评论
For cynosa keyboard the combo is Control, Esc, Caps
这个答案有帮助吗?
得分 5
6条评论:
dude i made an account just to thank you, i &&^&^$^ love u so much (no homo doe)
由完成的 分享
Made an account just to say thank you so much bro. I’ve been trying to fix this for so long.
由完成的 分享
don't work why?
由完成的 分享
Fukjing genius THANKS !
由完成的 分享
Esc and caps worked for me 2023. Type in keyboard name and “exit demo mode” and you should get it
由完成的 分享
显示更多的1条评论
添加一条评论
You need to:
If you don’t have M5 just press M3 or M2
这个答案有帮助吗?
得分 1
5条评论:
I don’t have any m keys, but I fixed it
由完成的 分享
由完成的 分享
Did the esc and other buttons... it installed drivers, said everything was good to go. It also shows up as a keyboard hid (human interface device) in device manager. Back lights work and change color with press of button. Not a single key besides the lighting effect work at all. My nephew asked me to see if i could make it work for him. I have no clue as to its condition or if it worked previously. But given it lights up and shows as keyboard and loaded drivers..... one would be inclined to think it would work. So far none of these solutions have actually been a solution for me.
由完成的 分享
FN + Space bar fixed it for me
由完成的 分享
Fn + Spacebar works for me.
If you are having this issue please be patient and try out all the suggestions here cause some might just worked. Thanks for sharing and helping me out
由完成的 分享
添加一条评论
the keyboard might be in bluetooth mode, check the manual
这个答案有帮助吗?
得分 1
添加一条评论
My keyboard has a key combination that when pressed locks the keyboard. Look up a command list for your specific keyboard and see if it has a lock command, this is what fixed it for me
这个答案有帮助吗?
得分 1
1条评论:
Bruhhhhh. Soo easyyyyyyyy xdddd
Thank You man! I could see a Lock Button on F9.
I pressed Fn+F9 and TADA! It's working. I am really grateful to you <3
由完成的 分享
添加一条评论
Depending on your model, the keys might be different
https://mysupport.razer.com/app/answers/...
Visit the above razer support website to find your keyboard key combinations.
这个答案有帮助吗?
得分 1
1条评论:
This helped me, thank you :)
由完成的 分享
添加一条评论
you have accidentally gone in to custom programming mode. fn+~ to get out of it
这个答案有帮助吗?
得分 1
1条评论:
THANK YOU SO MUCH I just made an account just to thank you!
由完成的 分享
添加一条评论
Well I will suggest you to update the keyboard driver some time an outdated keyboard driver can also cause this kind issue. You can update the keyboard driver manually or automatically for doing it automatically you can try a good driver updater utility tool like Advanced driver updater or driver easy are two good option to try.
这个答案有帮助吗?
得分 1
添加一条评论
hey kenneth,
it is very possible that you computer doesn’t recognize the keyboard as a keyboard see in device management if the keyboard shows up. if it doesn’t show up you might want to see if you can download and install drivers for it.
https://www.razer.com/synapse-2?_ga=2.92...
if it doesn’t show up as a keyboard grab anotherone and install razer synapse it helps with most software related device failures.
good luck
-M
这个答案有帮助吗?
得分 0
1条评论:
Mine shows up in device manager and everything lights up, but it doesnt type, its 60%
由完成的 分享
添加一条评论
Have u checked the device manager as suggested by martijn?
it is a good idea to provide with more information. Like what happened before the problem. For example pc was working fine yesterday, this morning when i turned it on the problem shows up.
Try to use an external keyboard but first
If you are on windows 10 and can still get to the desktop do the following if the mouse still works. At the bottom on the left side on the taskbar left click on the window. A windows will open and on the left side close to the bottom choose the second bottom up (like a wheel)(just a highlight will show setting). On the windows that opens all the way down choose Update & Security. On the next window on the left side choose, Recovery and on the right side choose restart now. After the pc comes back choose Trouble shoot and next screen, choose advance options and then choose start-up settings and click “restart”, when windows come back choose number 4 (safe mode). If the keyboard works after that then i will say ur pc is infected or the driver for the keyboard needs to be re-installed.
On windows 7 after the pc is turned on and after the logo start tapping on the F8 key and choose safe mode the rest same as above
If u still have same problem now use the external keyboard in safe or full mode. If the keyboard works fine the internal keyboard is bad.
P.S. I could give you more tips (or other ways to check your keyboard) but that requires more technical knowledge.
这个答案有帮助吗?
得分 0
添加一条评论
Unplug the keyboard
Press and hold
Esc and Caps lock
Plg the keyboard back
Restart your
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kenneth Paul Richburg 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 104
过去 30 天: 415
总计 227,463
