跳转到主内容
这里有各种关于P10维修指导
48 个问题 查看全部
Huawei P10 Antenna cable broken
So i was replacing the screen on my huawei p10 when i accidentally broke of the antenna connector on the board. i put the phone back together with one side on the antenna unconnected, thinking that the phone would work but i wont be able to make any calls. when i turned the phone one everything seems to be working fine. i am able to make calls and use wifi etc. My question is so i need the antenna, its currently not connected in my phone but everything seems to work fine
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
the network signal will be very low ( out of service ) cannot make call .
You can jumper the antenna very easy.
这个答案有帮助吗?
得分 0
1条评论:
is their a guide somewhere on the net?
完成的
添加一条评论
I had the same issue. Broken off the connector when replacing the battery.
I've broken the connector from the main board, that's where the camera is located.
Connected the bottom side of the antenna. Strange thing is that everything works perfect. But I dont know if I have a lower signal.
这个答案有帮助吗?
得分 0
添加一条评论
Same thing here. Did you encounter any problem?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tony 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 801
