l220 printer head moving without any sense
l220 printer head moving without any sense. head stack one side all led blinking problem.
i had change head cable, encoder strip and head sensor also but problem still.
please any solution.
HI,
Let me know more details about this problem.
I will help you to solve your problem.
May I ask?
When the answer from above question is yes then you need to replace counter chip then you can have your printer as normal again.
这个答案有帮助吗?
How to fix that kind of problem in printer?
Check encoder sensor or sensor cable to the mainboard, that is the main problem from this issue.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,304
1条评论
hope its good answer I'll check it. Thanks
由 Brook Fikrewold 完成的
