跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
276 个问题 查看全部
Battery discharging to quickly, please help
Battery on 2017 MacBook Pro discharges way too quick. Geniuses can’t find solution
Update (12/18/2018)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
What do you use the computer for? What programs do you run?
完成的
Install CoconutBattery and paste a snapshot on the main window with the USB-C charger plugged in and a second with it disconnected. 在已经存在的问题里加入图片 so we can see wants happening.
Are you using the original Apple charger and the cable that came with it directly to your system? Or, are you using a hub or dock to then plug in the charger or using some other power source?
完成的
ANTHONY, I use the computer for pretty much everything. I use Bible softwares such as Logos, and Bibleworks, also use office, OneDrive,Boom3D , clean my Mac , Acronis, Adobe, Polarr and Kindle. Those are my main ones. Oh and zoom.
完成的
Can you post the second snapshot with the charger disconnected and answer the other questions.
完成的
添加一条评论
1个答案
最有帮助的答案
Does it discharge even when turned off? If not, then try to factory reset your OS and test a longevity of working with battery power only. If that does happen faster than in tests of this MacBook from internet-reviewers than you’ve got something wrong with either battery or power relay (and repair techicians are an idiots, is they didn’t find a thing, probably). If time that MacBook lived on battery is close to those from reviews, then it was some software that used a lot of CPU or GPU time (probably).
这个答案有帮助吗?
得分 1
2条评论:
It does not discharge when turned off
完成的
Thank you for quick response.
I have tried that, and. It will last about 2 hours. Last night it went from 100% to 50% in five minutes. I was using Zoom which is a video chat app.
After paying just over $3000 in 2017, and still paying it off as well as getting Apple Care,
I’m still asked to pay enormous amounts for a new battery. I get the feeling that it is not the battery though.
完成的
添加一条评论
添加你的答案
bless_man777 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 106
