跳转到主内容
加入维修社区 - 创建账户
The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
Apple Watch does not power on...
I have an Apple Watch 42mm Series 1 and just recently installed a new battery and a force touch sensor. I tried to follow the guide as closely as possible when taking apart the watch and later putting everything back together. After I sealed it all shut, I placed the watch on the charger and all it does is flash the Apple Logo and would not charge or power on. Now, I’m wondering if perhaps something is wrong with the connections?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would take it back apart and make sure you have the battery connected properly. An iphone will flash an apple logo then reboot endlessly with no battery present. The watch probably does the same. If the battery is installed correctly then you may have a bad battery. The battery on the series 1 watch can be a little tricky to get it plugged in all the way.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Roman Laktionov 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 194
