跳转到主内容
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
132 个问题 查看全部
Apple Watch won't power up. I fixed it. Is it still Waterproof?
All reset efforts don’t work. Gets hot on the magnetic charger. Every once in a while the apple logo appears for a few secs then fades away.
Apple wants $275 flat fee to fix it. No way.
I feel comfortable taking it apart and replacing the battery. The question is: Is the problem with the battery? What are the odds it’s the battery and not something else?
Update (01/03/2019)
I followed the IFixit battery replacement video and successfully repaired the watch.
The old battery was significantly swollen. I was a little ticked that I found out Apple was repairing this problem in ser 2 watches, but failed to mentions that when I talked to apple support. They only wanted to charge me $270.
All the same the battery and adhesive strip were inexpensive, and after buying a Y000 tri-wing screwdriver, I successfully repaired the watch.
Here is my new question: How waterproof is the watch now? I used an adhesive strip, but it seemed so thin and flimsy I’m concerned at how waterproof the watch is now?
I saw another repair video that resealed the glass top with a B-7000” adhesive. Should I try something like that?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Unfortunately, the only way to know is to try the battery. Be careful opening the watch as to not rip the force touch gasket. If you do, luckily its a 5 dollar fix. I would try the battery or maybe even try disconnecting then reconnecting the battery and see if that fixes it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chazz Lavely 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 171
