跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2399 个问题 查看全部
Weak GPS Signal Signal
Hello Everybody
I have a great problem with my iPhone 4.
I have it complet teardown and change the screen to a White One.
After rebuild, all working fine.
But the GPS Signal strengt is false, in Navigon the GPS Signal is "blinking" Signal ON OFF in one Second.
The GPS Accurancy is 65m an i have no solution, i have change all Screws, Emi Shield and Antennas, but i have no Solution.
Thank for our help.
Regards Patrik
Sorry for my bad english :D
I
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
I had this problem with my phone, but in my case the issue were the solder joints in the motherboard (PCB). I took it off and put in the oven for 7 minutes at 190 C, then, my GPS started workin' great(the oven's heat can melt and fix cracks in it).
But in your case, as the GPS was fine before disassembling it, my guess is that should be something connected wrong. You changed the screws, but did you put then in the right place? You can't exchange them, every screw has your own place. Check the Wifi/GPS antenna connection (close to the battery connector) too, maybe it's not well fixed. At the top cover of the phone are five screws, the 1.4mm Phillips (step 7 - http://tinyurl.com/43aon77) has a nut under it that use to fall when we make some movements with the mainboard. If that happens, the contact between the screw and the PCB is lost. Try to check it too.
这个答案有帮助吗?
得分 1
添加一条评论
If you use your phone in the car so:
it may just be the frequency of the FM transmitter and not the device itself.
Try to changed the FM transmitter frequency and everything will work like a charm
这个答案有帮助吗?
得分 0
1条评论:
How to change the frequency of FM transmitter??
完成的
添加一条评论
Check the top screw contact washer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Patrik Laube 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 8,881
