跳转到主内容
加入维修社区 - 创建账户
PSP 300x 于 2008 年 10 月 15 日在美国发布。维修该设备仅需常见工具。
PSP has rainbowing/lines on the screen how can I fix this?
Hi i have baught this PSP 3000 in Red with a Xbox 360 at a Flea Market for the dirt cheap but it had a damaged UMD button so i bought a new UMD lever got out my crappy large solder iron due to my others not working anymore and melted off the old UMD Switch, cleaned up the iron and installed a the new UMD button put the PSP back together and the UMD drive worked but the screen didn’t work properly had lines and this rainbow effect with the bleeding colours the screen used to work just fine before installing a UMD Switch. So at first i thought i damaged the screen. So i ordered a new screen installed it and same problem so what could the problem be? Did i damaged some of the components on mobo near the UMD Button?
Pics of the mobo https://imgur.com/gallery/zcJBTOp
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Here are the pics of the mobo.
完成的
添加一条评论
2个答案
You probably melted/damaged the board with your soldering iron. Unfortunately you can’t really repair it unless you get an entirely new logic board/motherboard.
这个答案有帮助吗?
得分 0
1条评论:
Well i made sure to not touch the chip by taping it over with kapton tape but the UMD button has smd components near it look like caps must have damaged those. I’m not buying a new mobo as i baught this to resell.
完成的
添加一条评论
I do not know. Mine does the same thing. It never bothered me. It doesn’t interfere with gameplay.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Player 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 2,454
