跳转到主内容
Kindle Fire,也称 Fire 或 Amazon Fire,是 Amazon 推出的平板电脑。操作系统基于 Android,使用多点触控屏幕。拆卸维修仅需用到螺丝刀和撬棒。
How to remove circuitboard from 7th gen fire?
I don’t see any teardowns for the 7th gen fire (model SR043KL) and it seems to be significantly different from older models.
My goal is to examine/repair the USB power port (only working now when I apply a lot of force in one direction).
The upper right of the board (upper left in the photo) appears to have a cable that connects to something on the screen side. I don’t know the right way to unplug this connector. How should I remove it?
The black cable runs to the front. I suppose I need to unplug the gold ribbon side and peel up the component. But I don’t see how to release the connector. Which portion moves and in which direction? I’ve tried gently pushing the tan section of the connector up and toward the ribbon, but nothing moved.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I think that’s a ZIF connector. To remove it, use your fingernail or the tip of a spudger to flip up the black locking flap, then pull the cable. Hope this helps! Do it at your own risk. Happy fixing!
这个答案有帮助吗?
得分 2
1条评论:
Bingo. It is a ZIF, I'm just not that familiar with manipulating them. Knowing that the black part flipped up was what I needed. Unfortunately, it looks like I'm going to have to unglue/heatgun the cable from the board as well. Not looking forward to that part.
完成的
添加一条评论
最有帮助的答案
This video may help https://www.youtube.com/watch?v=kOu_2po6...
这个答案有帮助吗?
得分 3
1条评论:
Nice video (I definitely hadn't found it before), but it doesn't show any detail of how the connector is opened. I assume folks are just familiar with it . It does confirm that the cable has to be removed.
完成的
添加一条评论
添加你的答案
Darren 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 720
