跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 个问题 查看全部
Not turning on after crash.
Essentially my MacBook Pro crashed while I was opening QuickTime not too long ago and ever since I have not been able to turn it back on.
The only signs of life are when the MagSafe connector is connected with shows green and then allows me to push the battery indicator button. If I press the button immediately after plugging in the adapter it will rapidly blink the first LED and then any presses afterwards will flash all eight LED’s.
Other than that nothing else appears to work. I’ve taken apart the entire computer and there aren’t any obvious signs of damage.
Thank you in advance to any suggestions; I’m willing to try just about anything!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The flashing battery tester LED’s is telling me your battery is worn-out! You’ll need to install a new one. Here’s the needed part MacBook Pro 15" Unibody (Early 2011-Mid 2012) Battery and the IFIXIT guide to put it it MacBook Pro 15" Unibody 2011 年 早期 电池更换
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Battery图片
产品
$89.99
这个答案有帮助吗?
得分 0
6条评论:
Unfortunately, I don't think that's going to solve the problem. I was operating the computer on battery power when the crash happened, and it had roughly 100 cycles on it.
完成的
What is the MagSafe charger LED, Amber or Green?
完成的
Solid Green.
完成的
Shouldn't I be able to start it or see at least some kind of life with just the power adapter? Also, it doesn't exactly explain the seemingly random crash... Although I do recall possibly having read something about the battery being necessary to charge up a capacitor on the logic board.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Michael Stefanchik 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 58
