跳转到主内容
The Logitech G9/G9X is a laser gaming mouse. They are programmable and feature precision grips. Model numbers are: G9: M/N M-UAJ132 and G9x: M/N M-U0006.
Newly soldered in mouse switch not working
My right click on my Logitech G9x started having the double click problem, so i bought a soldering iron and a few new mouse switches to put in. I started with the left mouse switch, it took a while but eventually I got it replaced and it works and feels fantastic. After that, I replaced the right mouse switch and cannot get it to work. I’ve unsoldered and resoldered it and another new switch in a few times and have had no success. I’m wondering if maybe I damaged the pcb, even though I never applied the iron for more than a couple seconds and didn’t use more than 200 C. I’m also wondering if it is the solder I’m using. The solder came with the iron and is some cheap chinese 63/37. I think for the first mouse switch some old solder may have remained behind and formed the connection with the pcb. All the old solder was removed for the right mouse switch. So i was thinking about getting different solder. Here are some pictures of the pcb: https://imgur.com/a/lESeblT
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
that poor mouse, all of the pads that you are supposed to solder too have been ripped off and the only way to get it working again is to scrape away what is left of the trace and solder a jumper wire to it, i would recommend you then solder a piece of component leg to a different point on the pcb so the button has some support and wont break off because you completely destroyed the anker points
完成的
添加一条评论
2个答案
Or you might have connected two contacts of switch with solder. Can you take a photo of PCB with contacts soldered to it?
Also, did you use flux? It’s not that important, but it might be an issue (since it’s used to peel oxydized layer on contacts)
这个答案有帮助吗?
得分 0
2条评论:
I went and got some rosin core leaded 60/40 solder to try instead and still can't get it to work. Here are some pictures of the contacts, they look pretty $@$*!& but I've done soldered the switches in and out a dozen times so I'm struggling here: https://imgur.com/a/KUhOTOT
完成的
Ok, then it seems like you didn't use flux. Try again, but use flux on new switch and on contacts on PCB berofe soldering. That can eliviate the problex since oxydized layer on contacts can prevent electricity flowing through.
完成的
添加一条评论
You ruined the PCB, to get it work again you have to find where the pcb routes go and jump a new route with thin copper wire from another spot to the legs of the new switch. Those PCB’s on G9 series are so delicate and you can tear off the PCB while removing old switch (been there and made it work with jumper wire)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Re D 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 33
总计 3,173
