跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 个问题 查看全部
Need one replacement (short) screw for bottom cover?
After upgrading RAM, I was replacing the bottom cover, and one of the short screws went flying. Can you tell me the size, and ideally a source?
I see that iFixit has full screw kits, but they are $60 and out of stock besides.
Thanks,
Tom.
MacBook Pro 15" Unibody (Mid 2010 - Mid 2012) Screw Set图片
产品
$49.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I may be wrong but suspect it is a 3mm long Phillips screw and expect it's the same thread size as the longer (13mm) screws.
The screws appear to be a M2 thread with a #00 Philips head
EDIT
A quick search of eBay with "macbook screw A1286" shows a few kits for around $20.
HIH
这个答案有帮助吗?
得分 2
3条评论:
Richdave: this was very helpful, thanks! I'm pretty sure you are right about the size. I ordered some 3.5mm screws and will provide an update once they arrive.
Thanks again!
完成的
How did you make out?
完成的
My long-overdue update: the screws I ordered worked fine.
完成的
添加一条评论
添加你的答案
Tom Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 3,243
