跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
How do I fix a loose CPU
I bought this phone broken, the upper part of the aluminum frame was bent a lot. So I basically bent it back to its place, swapped front camera, sensor and the upper loudspeaker. Now I am noticing that the phone sometimes gets stuck in boot loop of sorts, and if i press the spot where CPU is, it boots up normally. Usually it works for 10-30 minutes or so, and then reboots, and starts the cycle again. So I’m thinking it’s the CPU’s fault, how can I sort this issue?
I am only a hobbyist, don’t know anything about soldering, but since the phone cost me 40€, I am willing to give it a try with something I am not experienced in.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The CPU is underfilled, meaning that it is secured in place with a form of epoxy. That limits the options somewhat as you can’t just do an oven reflow because the expanding solder balls have nowhere to go and typically bridge adjacent balls or blow out from underneath the IC.
The ideal solution is a reball but that is also fraught with danger as removing the CPU can damage the pads underneath.
So theoretically, this is probably fixable but in practice there are no guarantees it will work.
这个答案有帮助吗?
得分 3
2条评论:
Okay, well are there any guides or something I could follow to give it a try? I am assuming I need some equipment aswell? Thank you for your input.
完成的
You would need a hot air station, some flux and solder, a reballing stencil and solder paste etc...
完成的
添加一条评论
添加你的答案
Jere 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 136
