跳转到主内容
加入维修社区 - 创建账户
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
iPhone restarts when plugged in
Trying to make repair iphones for friends/relatives as a hobby. Encountered this problem with an i7 Plus. Whenever it’s plugged in it will restart after a few minutes. Doesn’t matter if it’s connected to pc or outlet. Tried different cables and restoring in DFU was succesful. Can’t get in the device to test more like sound etc with headphones, because it’s icloud locked, and she would come tomorrow. Is this a charging IC problem? Device got dropped in the toilt btw lmao
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Could be a charge port issue, If it doesn’t work after you get passed the iCloud lock, you probably will need to open the phone and let everything dry, then proceed to clean every component with 99% isopropyl alcohol. After this, replace the charge port.
这个答案有帮助吗?
得分 0
1条评论:
Replaced dock and still the same problem. It also happens when it's only plugged in with the lighting port side
完成的
添加一条评论
添加你的答案
KWH 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 282
