跳转到主内容
Repair guides and troubleshooting for the Acer Aspire V5, a series of laptops on the Windows OS by Acer.
132 个问题 查看全部
Laptop turns on but no display and fan stops after a few seconds
Hi
I have an Acer aspire laptop V5-551 and when I press the power button it boots up however there is no display on the screen and the fan stops after a few seconds.
What can this be down to?
I have recorded a video that shows the issue.
In the video you can hear the beeping when the laptop charger is unplugged.
https://youtu.be/bfJkH6PRVkE
Many Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
I think the GPU (graphics processing unit) is broken or uninstalled. Are there any beeps and did you change any settings before this happened
这个答案有帮助吗?
得分 0
1条评论:
I didn't change anything before this. When I put the charger in the laptop beeps
完成的
添加一条评论
This could be a few things. POST could be failing, You may need to reseat/replace your RAM, or most likely the device is over heating
这个答案有帮助吗?
得分 0
添加一条评论
Have you tried plugging in an external monitor prior to turning on?
Have you tried draining the power from computer by unplugging the power cable, removing the battery, and holding the power button for about a minute?
Do you notice the power button or the Caps/Num Lock key blinking any lights
这个答案有帮助吗?
得分 0
2条评论:
I have the same issue but I don’t hear any beeping. Laptop turns on, no keyboard blinking, fan starts and stays on for a few seconds and then stops. Laptop used to work fine. Model Acer Aspire 5750 i5….any other suggestions anyone ?
完成的
I have the same problem me 2 any suggestions?
完成的
添加一条评论
添加你的答案
Adeel Hussain 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 41
总计 2,158
