跳转到主内容
发布于2017年6月,iPad Pro 10.5寸替代发布于2016年的iPad Pro 9.7寸。
145 个问题 查看全部
Home button repair and reassembly?
I have the original home button from a ipad Pro 10.5 which I need to fix onto the new screen, however not sure what needs adhesive tape applied to it.
I know the home button bracket needs tape applied to either side but do the following also need it?
  • Does the rubber gasket need tape applied to it to fix the white plastic ring?
  • Does the plastic ring need tape fitted to it so it sticks to the glass?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I put adhesive on the ring and usually the gasket around the home button will keep it in place. Once the iPad is closed the space behind the home button keeps it in place unless there is some structural issues with the iPad or the gasket.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for replying... can i use adhesive tape as the adhesive both on the ring and rubber gasket?
完成的
Sorry for the late reply. No, just the ring. The gasket will usually stay in place with the help of the bracket that goes on the back of the button.
完成的
添加一条评论
添加你的答案
Nav 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 273
