跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
iPhone SE gets trapped in boot loop when screen closed
I just replaced the screen on my iphone se and it worked perfectly for a few days, then I reset it and it became trapped in the boot loop. I’ve opened it up and checked all the connections and everything’s fine and restored it through my computer. It works perfectly fine and battery charges and holds a charge, but only if I do not close up the screen. If I close the case, it gets trapped booting up again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It’s either a bad screen or there is a board-level fault with the logic board. Haven’t done any board repairs on this model yet so I don’t really have an idea what is the cause for it.
这个答案有帮助吗?
得分 2
3条评论:
Thanks for your help! I think I must have had a longer screw in a wrong spot. Once I removed the bracket and screws from atop the camera connectors, the screen could be set back and currently it's working.
完成的
My iPhone SE was run over by a car during a trip and when I got I got home I prepared the screen and made sure nothing else was wrong. then I gave it to a relative and they said that it had a lot of problems and needed to be fixed again. So, I realized the logic board needed the fixing. I replaced it and then now it reboots repeatedly and then crashes and the screen turns black, no one in the family can remember the passcode so it just reboots then tells me that it will be disabled for 5 mins. I’m pretty familiar with fixing phones and am pretty sure that it’s just the logic board or just some metal mechanism in the screen that his touching something its not supposed to. If anyone could help me or give me some advise that would be great!
完成的
Rebooting like that usually means either a bad battery or one or two components right above the battery connector have gotten dislodged or missing.
The components right above battery connector are responsible for recognizing the battery and the amount of power it can output. If the phone can't tell how much power it can take from the battery it'll take too much causing the phone to reboot.
完成的
添加一条评论
添加你的答案
KennethParcell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 51
