跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Home button not working
I replaced my battery and lighting connecter a few moths back. When I finish the job everything was fine. I cleaned my phone with a wet wipe and my home button started playing up (water damage maybe?). It used to work intermittently, then stopped altogether. Touch ID still worked, the eventually stopped also. I finally replaced the Home button the other day and its still not responsive. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Replacing the Home Button disables the TouchID - there’s nothing you can do about that from a DIY perspective.
However, I would check the condition of the flex cable on the original HB. Look for micro-tears or any other form of physical damage. It really doesn’t take much to cause failures. If that looks good, then check the condition of the flex/connector that runs underneath the LCD Heat Shield. It’s basically an extension fo the HB flex and once again, any damage to the flex or connector will impede the HB functions. This flex can be replaced if damaged.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Justin Badger 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 71
