跳转到主内容
The HP Pavilion G6-2249wm is a 15.6-inch laptop in the G6 series.
7 个问题 查看全部
Laptop screen gone black and it beeps when I press any key
I got this laptop quite a few years ago. Last night I forgot to remove it from charging, which has caused overheating and the windows has gone. Now when i start it, the screen remains black and on pressing any key it beeps.
What do i need to do now? Is my hard drive safe? Do changing the RAM will fix problem.
Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
May be the number of beeps will guide us to the problem and most of the time beeping with no screen will be a need to refix the ram after cleaning if it not works replacing the ram will be healthier
完成的
添加一条评论
1个答案
The first thing you could try before all that or after, preferably first, is to take out the battery and try plugging the charger in the laptop to supply in a more direct power. Then turn it on a see what happens.
Can you get to BIOS? Anyways.
  1. I am going to assume you have Windows 10. After turning on the laptop, keep pressing “F8”
  2. This will get to “Safe Mode” afterwards, go to “Troubleshoot”—- if you can get to Safe Mode thats a great thing to know. So tell me.
  3. After that go to “Reset your PC”
  4. Then press “Keep my files”
Doing so should reinstall Windows and hopefully fix your issue as I would primarily want to assume some OS hdd failure as its the easiest to start with. Especially since its just a black screen afterwards.
You could also try plugging the laptop to an external monitor and see if it boots. Once its hooked up to an external monitor.
Start up your laptop, and press and hold the function key which is the letters "fn" inside a box.
Press and hold this with the corresponding F# key that has the monitor symbol, which may look like this " lOl " or some variation of that.
Some laptops vary. Could be FN + F4 or F5. Seems to depend.
Try all this and tell me what happens.
这个答案有帮助吗?
得分 0
2条评论:
I encounter the same problem here, yesterday I was downloading some Windows 10 upgrade then suddenly turned off. This morning I tried to turn my laptop on, it only displays black screen and it beeps when i press any key.tried the solutions you mentioned above but none works, every time I try to press any key, it just beep. Yes, I can get to BIOS by pressing f12, but what to do next?
完成的
@Miu Miu In your bios find the boot order of your hard drives.
Make sure it is your primary hard drive. It may of actually installed windows but the bios thinks its boot order is still the flash drive, although taking it out should of rearranged it automatically.
If that does not fix your issue, get your flash drive with windows 10, and the same thing but boot with your USB. And try installing windows 10 again, follow some guide on how to install windows 10 with USB (may know how to do it already but I can't be too safe in my response.)
https://www.youtube.com/watch?v=tjmRWFep...
Nothing with your laptop is broken, the installation just went wrong and something with the bios is not recognizing your hard drive or your hard drive failed to install windows properly.
Sorry this is late!
完成的
添加一条评论
添加你的答案
bhupesh 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 65
总计 5,644
