How to fix Windows not open or close on Lexus GS350?
I have a Lexus GS350 2007. recently the windows is dead or stuck. I only can open or close the driver side.
Thanks
Jeff
If only one window had failed I'd suspect that window's motor or regulator, but given all but one have failed, I'd guess it's a body electrical problem. I could see the driver's window being wired a bit differently because usually it doesn't respond to the "window lock" switch in my experience, but I'm not sure how it works on a Lexus GS.
How amenable are you to doing electrical troubleshooting? If you're not, you might want to find somewhere to take it. If you are, it would be nice if you could find some schematics. I don't know where to look for Lexus ones, but they may be available online. Ideally you'd get a copy of the factory service manual but that can run into the hundreds of dollars for some brands.
In any case, I can think of two possibilities:
Sorry I don't have more detailed information!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,147
