跳转到主内容
A budget-friendly Axon Pro, released fall 2015.
9 个问题 查看全部
How to re-programmed the ZTE Axon?
May phone stopped working long ago i want to restart it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I believe you can hold the “volume up” button and “power” button simultaneously for five seconds. If done correctly, assuming the phone is charged, from there, you should be able to press volume up and down button to enter the boot menu. Try the “reboot” option to see if the phone is still operational so that you may recover pictures, contacts, etcetera, or continue using the phone. If this fails, go back to the boot menu and try the “update from cache” option. Then, if that fails, try the wipe/reset option. Good luck.
这个答案有帮助吗?
得分 0
1条评论:
The problem with my device is that, after I did as you said in the answer above it used to show me that 'unfortunately the phone has stopped' and I press OK it showed me 'unfortunately the fingerprint has stopped'. what is the solution?
完成的
添加一条评论
添加你的答案
derouiche djamel din 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 101
