跳转到主内容
加入维修社区 - 创建账户
The Dell Inspiron 15-5565 is a 15-inch laptop computer made by Dell.
Laptop doesn't power on
Opened my laptop to clean out the fan. After I reassembled it, it worked fine, but I realized it was not charging. I took it apart again and realized that i forgot to re connect the adapter port to the mother board. I reconnected it and reassembled and now the laptop will not power on. Nothing happens when I press the power button.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi Andrew, when you connect the power adapter to your computer, do you see an indicator that there is power?
try reseating the LVDS cable to the power button to the main board.
完成的
GPU and CPU are integrated on the board. Is it possible I shorted a power rail the second time I took it apart?
完成的
添加一条评论
1个答案
You can take it apart again and see if you find anything along the way. Check the seating of the video card, CPU [ and the cam on the CPU ] and memory. It may work when you put it together, if so you have had a win. There is also a chance you have done nothing wrong, it may have been ready to fail next power on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew Young 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 234
