跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
ran over and now bootloping
a customer brought in a 6s plus that was ran over by a car. they want to get it fixed to retrieve the data thats in the phone still. surprisingly the board dosent look bad and the housing wasnt even bent or anything. the issue im having is when i initially connect it to dc power it draws .01a for a second then goes to 0 and stays, until i prompt to boot. it turns on a shows the apple logo for about 3-5 seconds then cuts off again. (while it is on the boot current seems normal.) i havent tried to update or restore because i dont want to risk the data. so far all ive done is measure nand power rails and reball the nand to no avail. i also did a full visual inspection and cant find any cracked or visually damaged components. just posting to get some ideas
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It’s a pretty risky approach to just reball the NAND without really understanding what’s wrong with the device. You could damage the chip or the logic board during the process, to the point where it becomes difficult to retrieve data.
When dealing with a dead device, spend some time to do at least some rudimentary probing. Check the main power lines and the main PMIC outputs (PPCPU/GPU, SOC, FIXED, SDRAM, NAND etc). If that looks good, then check the main BBPMU outputs.
Because the phone was crushed, it may just end up being a few bad solder balls somewhere but before applying tons of heat, try to rule out the easy stuff, like subsystem shorts.
这个答案有帮助吗?
得分 2
5条评论:
i checked the main power rails and did probe around a bit before just reballing the nand. i did that because i saw a dent in the back of the phone near the nand and it was tuning on just not booting up. i got it working now so all is good. ty the the input though
完成的
just cba listing every point that i probed if i can even remember them all... lol
完成的
also how is reballing the nand risky? its pretty straight forward. with large balls far apart and no nearby underfilled chips. the only thing on the other side of the board is the sim tray.
完成的
On an iPhone logic board, underfilled parts are never really far away :>). Applying heat for anything always has risks. If you lift a pad or are not sure the chip was properly seated, then you have to rework the pad and apply heat a second time to double check.
Of course, you're skill level will have a direct correlation with success, still, it's a "best practices" point of view.
完成的
Thanks Luke!
完成的
添加一条评论
添加你的答案
lukerockhill 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 6
总计 66
