Hdmi port failing in Xbox one X
It works, sometimes, I have to tweak the cable to a certain angle for the connection to fully work. I just need help finding a quick tutorial on how to replace it or reseat it.
The HDMi Port is soldered to the main board there is no easy fix for this unless you are able to solder, Have you tried another HDMI cable ?
If that dosnt’t work try cleaning the port with a cotton Bud and some rubbing alcohol if you have it.
这个答案有帮助吗?
I don't have an answer but , I have the same problem. Sadly now it completely as stopped working .
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 2,719
