跳转到主内容
Why is my monitor saying no signal?
My friends PC hasn’t been working at all we thought maybe it was the monitor but it worked fine when plugged in to laptop the build is https://pcpartpicker.com/list/RGtQYT this includes the monitor but it just won’t work we tried methods to the monitor and checking all ports from GPU to CPU to hard drive nothing seems to work if anyone could help fix this that will be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Hi @agoodname ,
Did you try removing the graphics card and see if there is an output from the onboard video HDMI or DVI-D ports? At least to get into BIOS and check the video settings.
完成的
Process of elimination first. Make sure that the monitor is good. Then make sure the GPU is good. Also check the cable is good. Before you know it you'll have a spare cable, monitor, and GPU (or switching to onboard as @agoodname said) to be sure.
完成的
We tried removing the GPU and just going straight off the ports of the motherboard but it still says no signal my guess was the CPU, but i didn't see any ports for the CPU that was off. If you like screenshots add me on discord @GtsbeastFX#5218
完成的
添加一条评论
3个答案
已选择的解决方案
Sticking the ram in and back out works thank you Brett I found out my friend didn’t lock it fully
这个答案有帮助吗?
得分 1
1条评论:
Haha amazing bud. Just took apart my PC, did a paintjob, put it back together and my PC was doing the same thing! Just took the ram out, cleaned it and made it sure it hooked up well, and I fixed my issue :)
完成的
添加一条评论
最有帮助的答案
Make sure your RAM is properly connected. Take it out, clean it, and replace it. Worked fir me.
这个答案有帮助吗?
得分 2
添加一条评论
So the system turns on but no display?
Have you tried different connection cables, such as VGA, or DVI on the GPU?
I trust your GPU is connected properly.
Try taking out the GPU, and plugging your connection cables directly to the motherboard and see if that boots.
这个答案有帮助吗?
得分 1
5条评论:
yes, I've tried that but it still won't work i lost my sanity trying multiple things.
完成的
Are you sure its actually powering on? Do the fans run when it is powered up? Are you getting normal beeps? Is the HDD spinning?
完成的
Hmm. Try taking a stick of ram out for me. Try both by themselves and eventually try taking both out. Afterwards at that point, it would either be a mobo or cpu issue. Try doing that for me and coming back.
And the HDD would not prevent it to boot in ANY way. It would prevent the OS to boot but never the BIOS.
完成的
I'll try it out Brett
完成的
@agoodname
Alright tell me how it goes.
完成的
添加一条评论
添加你的答案
agoodname isgood 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 64
总计 47,071
