跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
Can I test a screen before completely installing it?
So I’m pretty sure I know the answer to this - but can I test out the screen replacement without hooking up the camera, home button, etc? Can I just attach the three cables to the phone to make sure the screen works, or would it brick the phone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You should always test the screen before transferring over all the small parts. It won’t cause any damage to the phone. However, without the Home Button, the boot time may be longer. If the screen works fine, then transfer over the FCAM/HB and then test again before sealing the device.
Be very careful with the flex cables as they can tear quite easily.
这个答案有帮助吗?
得分 2
1条评论:
Thank you. :) For some reason I was under the impression it would brick the phone. >.<
完成的
添加一条评论
添加你的答案
Sarah Ybarra 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 272
