跳转到主内容
The Asus K550L is a 15-inch laptop released around the year 2013. It has an Intel Core i5-4200U processor and an Nvidia 820M graphics card inside. It is very similar to the Asus X550L, so guides for each laptop can likely be used interchangeably.
3 个问题 查看全部
Compatible audio jack replacement part?
I’m having issues with my headphone jack and want to try replacing it, but can’t seem to find a part specifically for the K550L. Would a jack from another K series be compatible? And if not, where would I find a good replacement?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Just curious if you have tried using rubbing alcohol on a q-tip to clean out the jack. Sometimes dust gets repeatedly smashed between the contacts and forms a film.
完成的
Thank you Isaac, I tried this as per your advice, and there was some dirt in there. However, it did not solve my problem, which is my computer will show a popup of "you just plugged in an audio device" when there are no headphones in, cutting off the speaker audio. (Additionally the headphones have to be in the exact right position for audio to come through clearly.)
完成的
Update your device manager for audio devices and check if the popup problem is resolved. And for jack is it lose or tight if it is loose then you have to do some adjustment by tighten up the jack
完成的
Thank you Amily, I tried updating my audio drivers, but it did not help. Any advice on how to properly tighten the jack?
完成的
添加一条评论
1个答案
Most of these jacks short out the internal jack pieces to allow for the speakers to work. In other words, inserting a headphone plug will interrupt the normal flow to the speaker and send it to the headphones. That being said, along with your description of what is happening here, I would suspect a bad connection on the board for the jack itself. If the solder connection is bad and loses connection to the board, it will appear to the system that a plug was inserted. That poor connection would also explain the requirement for an exact position for the plug as well. When in that particular position, the connection to the board is made.
I would open up the unit and look at the connections on the board at the jack. If you can, take a picture and post it here as well. Hopefully a simple resolder of the joint is all that will be required.
Dan
这个答案有帮助吗?
得分 0
2条评论:
Hello Dan, thank you for your reply. I'm not sure how to attach an image so I'm posting a link at the end of this message. https://66.media.tumblr.com/d5cda4265ae0...
完成的
I can't tell form that picture, but it won't hurt to try and re-solder the connections for the jack. Try that first and see if there is any change in the behavior. If not, then the jack needs to be replaced. Measure the dimensions of the jack. Mouser or Digi-key will likely have a replacement, but you will need to match the size. This appears to be a 6-pin surface mounted jack.
完成的
添加一条评论
添加你的答案
Aarin Miller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 224
