跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Replaced battery, now computer shuts down randomly
My battery wasn’t doing great so I replaced it with a battery from iFixit. Replacement went fine, battery was charging, but now, I can be working on battery power and suddenly the computer will turn off. Not shutdown, but a complete power pull. It’s as if the battery is suddenly not recognized. The first time this happened, I fixed it by opening up the case again and making sure the battery was properly seated, which it was. It has since happened again, and upon powered reboot, the computer doesn’t recognize that there is a battery there.
I’m at a loss as to why this is happening and would appreciate any assistance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Maybe the wires to the connector from the battery are faulty, like loose contacts. Check if all are firmly connected and or use a volt meter to check it
完成的
添加一条评论
1个答案
Dear Friend.
It happening because of the battery cant drive the laptop ( not getting enough current).
Just try another Battery. (first try cleaning connector pins)
i think it will fix
All the Best
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Megan Sullivan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 128
