跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
iPhone 4s bootloops. Can't restore. Error code 3uTools -2
I managed to successfully flash iOS 6 onto an iPhone 4s and it worked fine. I then had to put the back cover on and put a few covers back and when I was doing that, I accidently shorted the battery positive to the case. It was only for a fraction of a second and judging by the location, shouldn't have harmed anything. Even so the battery is pretty much dead anyway. Now onto the strange stuff. When I tried to power it on after this, it was stuck in a short bootloop and wouldn't turn on. I have tried both iTunes and 3uTools to recover the phone but I get error 21 with itunes and error -2 on 3uTools. Any suggestions much appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Managed to solve this by replacing the battery with my lab power supply. This is definitely a battery-related issue.
完成的
Yes, error 21 was associated with battery issues.
完成的
添加一条评论
2个答案
Hi
a repair guy here. As the iphone 4S is pretty sturdy, touching the case with the battery connector should not damage the phone.
And iff I understand your problem correctly it is pretty similar to not having the battery connected at all.
Try to disconnect the battery and see what happens if you put the cable in. It will show the apple logo for a few seconds, than go black and restart.
During an update or booting it there is a moment it needs battery power even with the usb cable connected to the phone.
If if that’s the same as when you have your battery connected, you’ll need to exchange the battery.
If that doesn’t work check the connector soldered to the motherboard. These are known for some wobbly soldering points. You might have damaged them when disconnecting the battery.
Last at thing I can think of, is to test with an new dock connector flex, but that is not something that is usually related to error 21.
这个答案有帮助吗?
得分 0
1条评论:
I managed to temporarily fix this by powering the iPhone from my lab supply. I've ordered a new battery anyway. As you said, I noticed that it needs the battery during update and just reboots (not going into recovery mode) at some point.
Thanks for your help. You might be helpful in the future!
完成的
添加一条评论
Unable to restore iDevice(-2).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jamiebrowm 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 2,227
