跳转到主内容
加入维修社区 - 创建账户
Bowers and Wilkins P5 耳机于 2010 年发布,配有可更换的耳垫和线缆。P5 Series 2 于 2014 年发布。
Why does my bluetooth connection keep disconnecting?
Brand new B&W P7 Wireless headphones and they keep disconnecting at times over and over and at times they work for an hour perfectly.
So the bluetooth adapter I’m using (Avantree new saturn pro) is working flawlessly with my bluetooth speakers from JBL, therefore my assumption is that my Bowers & Wilkins P7 Wireless headphones are faulty (the integrated bluetooth).
Can someone confirm this?
In a few days I will receive a new bluetooth usb-adapter to confirm it is really the headphones and not the bluetooth adapter but that is already pretty obvious.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Do you have the replacement battery for B&W P5 wireless headphone? It could be original or equivalent. I will appreciate your response.
由完成的
I don't have a replacement battery for the model B&W P7 Wireless, since I had to return the presumingly defective pair of headphones.
由完成的
添加一条评论
1个答案
已选择的解决方案
[SOLVED]
The headphones were never defective!
Either the bluetooth adapter from “new saturn pro” bluetooth class 2 by avantree is garbage, the signal too weak or it is defective.
Since I got another bluetooth adapter by avantree, the so called “LEAF” which is bluetooth class 1 (best class), it works flawlessly with the new replaced Bowers & Wilkins P7 Wireless.
When I tried the new replaced B&W P7 Wirless with the “defective” bluetooth adapter “new saturn pro” it turns out to cut out the sound all the time, as much, that you can not enjoy any audio coming through it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
DirtyHarryOne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 26
总计 4,288
