跳转到主内容
The Neato Botvac 80 was released 2014. Part number 905-0079.
3 个问题 查看全部
Neato Botvac D80 issue.
I own 2 of these units (identical). By swapping a couple parts I have determined that the battery, and charger base are not the problem. Bad unit has no power at all. If I put it on the base to charge, Home button lights up green, tells me to turn the switch on (it’s already turned on, but I press ok anyways). Home button turns to amber (slow blink to indicate charging has started). After between 10-30 seconds, it changes to rapid amber blinking on home button and after about 3 seconds it shuts down, reboots and starts the process all over. Ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论:
Hi Jeff, got the exact same problem. Figured it had to be a faulty on/off button so I swapped it for a new one, only to find out that was not it...Did you ever find out what the problem was?
完成的
添加一条评论
1个答案
I just successfully repaired a Botvac D85 that had a similar issue. I connected my computer to the USB port and saw an error flash that said the battery was overheated. This caused the main board to automatically power off. The root cause for mine was the Fuel Gauge IC. It took a hot air station and some patience. You might give this article a look. http://www.robotreviews.com/chat/viewtop...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeff 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 538
