跳转到主内容
Won't boot past blue screen after software updates
Fixing up an old MacBook Pro (2,2) for my mom, here's what I did:
Wiped the drive clean and installed Snow Leopard on it, maxed the RAM at 3 GB and put in a new battery.
After I boot the machine and run software updates, it will not boot past the blue screen. Afterwards if I let the battery run all the way down and let it sit over night it will boot.
Here's the suggestions I've tried:
-Zapping the PRAM ect...
-Repairing the permissions and the disk itself
-Re-seating the RAM
-Putting the old RAM back in
-Safeboot, it will boot into safeboot
-fsck in single user mode
-Clean re-install of the OS
My questions would be the following:
-Has anyone seen this before?
-Is this a symptom of anything hardware specific (Drive failing, Motherboard ect...?)
-Anything I have missed?
Thanks a head of time.
UPDATE:
So replacing the drive did help in the fact that I now can get it to boot right away but only after re-setting the SMC. So I am unsure why the SMC needs to be re-set after each software update that I do, but otherwise it will not boot beyond the blue screen again. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Is this the 2.16 or the 2.33 GHz machine?
完成的
So it turned out to be that the hard drive was failing after all, I used SMART utility to diagnosis this and an iFixit guide to swap out the drive. Thanks for everyone's help! Also of note: the Apple Hardware test did NOT catch the drive failure...
完成的
Change the hdd thats it ...
完成的
添加一条评论
2个答案
已选择的解决方案
Shut down the computer.
Unplug the computer's power cord.
Remove the battery.
Wait fifteen seconds.
Press the power on button for 10 seconds.
Attach the computer's power cord.
Press the power button to turn on the computer.
这个答案有帮助吗?
得分 3
添加一条评论
try to remove the hard drive and boot through the dvd without hard drive . if it boot to the welcome menu . then put the hard drive back and remove all the partitions and restart ur laptop and reinstall the mac.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kellentat 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 9
总计 2,926
